HSRP with Secondary IP
vinoth.kumar
we are using the two 7206 VXR NPEG2 router as our backbone router and we planned to confiure the HSRP between the router
BGP PRI:
interface GigabitEthernet0/3
description BGP-PRI
ip address 2XX.XX.XX.252 255.255.255.0 secondary
ip address 2X.20.XX.17 255.255.255.0 -- ISP Link A
duplex auto
speed auto
media-type rj45
no negotiation auto
Standby 30 IP 2XX.XX.XX.254 secondary
Standby 30 priority 110
BGP -SEC
description BGP-SEC
ip address 2XX.XX.XX.253 255.255.255.0 secondary
ip address 2X.34.XX.44 255.255.255.0 -- ISP link B
duplex auto
speed auto
media-type rj45
no negotiation auto
BOth routers are using the IOS version
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-K91P-M), Version 12.2(31)SB10, RELEASE SOFTWARE (fc2)
now our issue is when i configure the Standby 30 IP 2XX.XX.XX.254 secondary the router througing a error message that
% address cannot equal interface IP address
same if i configure on the BGP Sec its accespting
kindly let me know what might be the root cause
5 Replies 5
andrew.prince
Level 10
Level 10
try removing the "Secondary" key word from the standby 30 group config.
HTH>
Thanks for your input
If i remove the secondary keyword how the HSRP will chose the redunacy
could u pls explain the things since i havent tried before
since we have primary ip for the interface how i can run HSRP for secondary IP alone
Vinoth,
please read the below HSRP Guide/Case Study:-
http://www.cisco.com/en/US/docs/internetworking/case/studies/cs009.html
HTH>
description Telicity-PRI
ip address 2XX.20.XX.17 255.255.255.0
ip address XX.58.14.252 255.255.255.0 secondary
duplex auto
speed auto
media-type rj45
no negotiation auto
standby 30 ip 2xx.58.14.254 secondary ----- when we enter the command it shows below error and not accepting the command
Can i know why the errors are highlight
pauloroque
Try to make the addresses XX.58.14.25x the primary addresses and the recreate the hsrp without the 'secondary' keyword.
Paulo Roque
