Warning message
command authorization failure
Jun 17th, 2009
When logging to some of our routers, we get sometimes (not always!!!) a command authorization failure, sometimes the command works, sometimes the same command fails, also in the tacacs logs there is no trace of the attempt to log in on this router.
Jagdeep Gambhir Wed, 06/17/2009 - 05:05
  • Red, 2250 points or more
We need to check the debugs as that will let us know why the command failed.
debug tacacs
debug aaa authorization
What is the IOS ver running on the routers?
~JG
Do rate helpful posts
lni1 Wed, 06/17/2009 - 05:38
Version 12.3(26)
As you can see in attach, the "show version" command failed twice, the third time it works !!
