NAT - config Review
Jun 17th, 2009
I need to allow only http traffic on the natted IP ( via acl ) and block all connection initiated from outside to inside.
Only allow connection initiated from inside to outside
M i missing anything,
********Configuration ******************
ip subnet-zero
ip domain lookup source-interface FastEthernet0/0
ip name-server
description Connected to ISP
ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Connection to LAN-Switch
ip address
ip accounting output-packets
ip nat inside
duplex auto
speed auto
ip classless
ip route
ip route
no ip http server
no ip http secure-server
ip nat inside source static
access-list 50 permit
access-list 50 deny any
Jon Marshall Wed, 06/17/2009 - 03:32
Where is acl 50 being used ?.
Can you just clarify, you want
1) all internal clients to be allowed to initiate connections to the Internet
2) you want to allow internet access to on port 80
If this isn't what you want can you be more specific.
ronald.ramzy Wed, 06/17/2009 - 04:17
ACL 50 was earlier used with IP NAT Pool which i removed with static NAT.
(1) all web traffic from inside goes to ISA server. so I want Microsoft ISA Server to initiate traffic from inside to Outside
(2) No traffic should initiate from Internet to Microsoft ISA Server
Since there is no firewall, I want to secure the connection as much as possible
John Blakley Wed, 06/17/2009 - 06:45
If you're wanting to allow traffic from the outside in, you can do one-to-one nat (like you are) and then block with the acl:
ip access-list ext OUTSIDE
permit tcp any host eq 80
permit tcp any any established
deny ip any any
int fa0/0
ip access-group OUTSIDE in
