Extension mobility in CM 7
Jun 17th, 2009
Extension mobility service is not showing during subscribe/unsubscribe list in Call Manager 7. I have configured the device profile/device default profile. I have activated the service, but still I see Assistant Pri Svc-Pool 1,2,3.. and Intercom calls.
Any help will be appreciated.
Jaime Valencia Wed, 06/17/2009 - 06:13
And have you subscribed the phone and UDP to EM????
You only mention you created and activated the services, never that you subscribed phone and UDP
If you're following the EM config guide you're skipping steps, read carefully the guide
if this helps, please rate
wahidayat007 Wed, 06/17/2009 - 08:32
when I go to subscribe list, it does not show the extension mobility services which was created and configured from the Device settings then Phone services.
So how I can subscribe ? But I selected the first available service and clicked next and renamed, it worked fine. Tested
