Netconfig - JOBS
Jun 17th, 2009
when i shedule a job in one of my switch(catos 4006 series) the job fails with the below error
Command(s) failed on the device Could not enter ENABLE Mode from USER Mode on Device. TFTP: Tftp is supported only for config mode commands. Could not detect protocols running on the device Could not synchronize RME archive with Device Config
Joe Clarke Wed, 06/17/2009 - 08:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This error indicates a problem with the enable password in DCR for this device. Make sure it is correct. If you are using telnet as a deployment protocol, you can also start a sniffer trace on the LMS server, run the job, then look at the trace to see what credentials are beign used, and what error is being encountered.
