thotsaphon Wed, 06/17/2009 - 06:26
  • Gold, 750 points or more
Mohamad,
1. Yes,It's a Layer3 switch. It supports routing. However,It depends on which IOS feature set you are using as well. RIP should be fine.
2. PVLAN is a security feature on the switch. Let's say you have a policy to block talking between particular ports in the same vlan. This feature can be used across multiple switches. Please check out this link :http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a008017acad.shtml
Edit: Sorry I missed reading something. You mean,cisco 3560 switch. Right?
HTH,
Toshi
engmohamad1980 Wed, 06/17/2009 - 07:44
yes right i mean 3560, thanks .
if I'm connecting this switch using the fiber to switch 2960TC-L using module GLC-SX-MM (SFP ,LC connector SX transceiver )
no problems
