Two switch in server mode
Jun 17th, 2009
Hi all,
If two switch is configured as server mode with same vtp domain (ABC) but different Configuration Revision and going to be connected together.
Is it the largest configuration revision switch (Switch-2) will be the Active role so that it will copy all Vlan information to Switch-1
or
they will copy all Vlan each other
Switch-1# sh vtp status
VTP Version : 2
Configuration Revision : 200
Maximum VLANs supported locally : 254
Number of existing VLANs : 11
VTP Operating Mode : Server
VTP Domain Name : ABC
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
Switch-2# sh vtp status
VTP Version : 2
Configuration Revision : 250
Number of existing VLANs : 100
glen.grant Wed, 06/17/2009 - 06:55
  • Purple, 4500 points or more
Yes the server that has the highest revision will overwrite the other servers vlan database .
Jon Marshall Wed, 06/17/2009 - 06:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jack
The switch with the highest configuration revision number will overwrite the vlan database of the lower switch.
Jon
iyde Wed, 06/17/2009 - 13:17
  • Silver, 250 points or more
... and that's exactly the reason why you have to be CAREFUL when working with VTP in server/client mode, as you will be able to shut your whole entwork down accidentially in the case where you put on a switch to the entwork with a higher revision number than your current VTP server and the new switch has only a few VLAN present.
Leo Laohoo Wed, 06/17/2009 - 14:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
For a VTP Server to over-write another, you have to have a higher revision number but also the same Domain Name and the the same Password. If the password is incorrect, the database will not be copied across.
iyde Sun, 06/21/2009 - 12:21
Good point regarding the VTP password.
This one can be seen with the "show vtp password" command - it is not seen in the "show vtp status" output.
HTH.
