VSS device marked as "Unknown" in DFM 3.1.0
Jun 17th, 2009
Hello
I have LMS3.1
When I import device in DFM =(3.1.0) the Cat-6506(sw 12.2.33) configured as VSS device are not known.
Allthough the other Cat-6506(Sw 12.2.33) not configured as VSS are known.
Have you an idea?
Michel.
Marvin Rhoads Wed, 06/17/2009 - 07:42
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
According to the supported device table for LMS 3.1 (http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/device_support/table/lms31sdt.html), only the 6513 flavor of the VSS is supported. (objectID 1.3.6.1.4.1.9.1.896). That seems counter-intuitive, since it's the Supervisor that makes it a VSS, but may be the case. Can you tell us the objectID of your target VSS switch?
Perhaps jclarke can weigh in with a more definitive answer.... Joe?
mmisonne Wed, 06/17/2009 - 08:13
Yes indeed, snmpwalk on the VSS 6506 device tell me: 1.3.6.1.4.1.9.1.896
Michel
mmisonne Thu, 06/18/2009 - 02:39
If oid of 6506-VSS is the same as OID of 6513-VSS , why does'nt it work ?
Do I need to upgrade DFM 3.1.0 to 3.1.3 ?
Michel
mmisonne Tue, 06/23/2009 - 08:18
Do you think it is a bug with VSS ?
Michel.
