CSM problem with header/cookie size and policy
langerc
Hi everybody,
I have a problem using slb-policy in vserver configuration. Requests with longer cookies will lead to a reset by the csm. But this only happens if there are one or more policies configured.
If there is no policy everything works fine.
I tried different software versions, all with the same result.
Does anyone of you have an ideas how to fix the problem?
regards,
Christoph
PS: Here is the configuration of my lab environment:
map PICTURES url
match protocol http url *pictures*
map AIRCRAFT url
match protocol http url *aircraft*
map HOMEBASE url
match protocol http url *homebase*
real SERVER1
address 10.10.10.101
inservice
real SERVER2
address 10.10.10.102
inservice
serverfarm AIRCRAFT
nat server
no nat client
real name SERVER1
inservice
real name SERVER2
inservice
serverfarm BUG
nat server
no nat client
real name SERVER1
inservice
real name SERVER2
inservice
serverfarm HOMEBASE
nat server
no nat client
real name SERVER1
inservice
real name SERVER2
inservice
serverfarm PICTURES
nat server
no nat client
real name SERVER1
inservice
real name SERVER2
inservice
policy PICTURES
url-map PICTURES
serverfarm PICTURES
policy AIRCRAFT
url-map AIRCRAFT
serverfarm AIRCRAFT
policy HOMEBASE
url-map HOMEBASE
serverfarm HOMEBASE
vserver BUG
virtual 10.10.10.52 tcp 0
vlan 101
serverfarm BUG
persistent rebalance
slb-policy AIRCRAFT
slb-policy HOMEBASE
slb-policy PICTURES
inservice
vserver NOBUG
virtual 10.10.10.53 tcp 0
vlan 101
serverfarm BUG
inservice
Gilles Dufour
Try to increase the parse length to its maximum
gdufour-cat6k1(config-slb-vserver)#parse-length ?
<1-4000> maximum number of bytes to parse
This should help with large http header/cookie.
And if that's not enough, use the following variable to increase the parse length
gdufour-cat6k1(config-module-csm)#do sho mod csm 5 var | i PARSE
MAX_PARSE_LEN_MULTIPLIER 1
Gilles.
Gilles Dufour
Gilles.
