Rate-limit CIR/bc/be Confusion
Jun 17th, 2009
Hi, I have to limit WWW Syn packet to 500Kbs. I am confused by CIR, be & be has been choosen like following --
access-list 192 permit tcp any any eq www sync
int f0/1
rate-limit output access-group 192 496000 4000 4000 conform-action permit exceed-action drop
Istvan_Rabai Wed, 06/17/2009 - 22:48
  • Gold, 750 points or more
Hi Rupesh,
Don't forget the following:
496000 means cir in bits per second (bps).
4000 means bc and be in BYTES.
For rate limiting the recommended values for bc and be are the following:
bc = (1.5 x cir)/8
be = 2 x bc
This would mean the following recommended configuration for the rate limit command:
rate-limit output access-group 192 496000 93000 186000 conform-action permit exceed-action drop
Cheers:
Istvan
Rupesh Kashyap Thu, 06/18/2009 - 00:31
1. At first, I have requested for 500kbs, they why CIR is 496kbs ?
2. Bc will CIRx125ms, which is not 93000 ?
3. Why be = 2x bc
Joseph W. Doherty Thu, 06/18/2009 - 06:45
BTW, I wonder whether your requirement might be better provided by something like the "TCP Intercept" feature.
