Problems installing device packages in RME 4.0.6
Jun 17th, 2009
I am trying to install device packages into RME 4.0.6 and running into dependency problems I can't resolve. For example, the Readme file for LibSwim.RME40.v1-8-7.zip states that the software dependency is RME 4.0.6 and MDF 1.25 and the only package dependency is LibCommon.RME40.v1-3-5.zip.
RME 4.0.6 is installed.
<NMSROOT>\lib\classpath\com\cisco\nm\cwcs\mdf\mdfdata.xml claims to be "version : 1.26 (001) Last Modified on mm-dd-yy:03-31-09 ". However, I see references to V1.27 being installed in the PSU.log
The CS device update package map states that LibCommon is at version 1.3.5
If I attempt to install LibSwim from the command line this is what I get:
C:\LMS Patches\RME\Device Updates>"\program files\cscopx\bin\psucli" -p rme -ins
tall -src . LibSwim
Services might be restarted, as a result of install operation
Would you like to continue ? ( Press y or n )
y
Proceeding with install..
Loaded psu.properties..
INFO: Installing for rme
Locking the package repository...
got all packages Repository
Checking Dependencies...
WARNING: LibSwim(1.8.7):Consistency check failed for base package SharedSwimOpti
calSwitch
There are no Packages to be installed
Released the Lock...
No package(s) to install for Resource Manager Essentials
So where does SharedSwimOptialSwitch come from? I don't see a package for it anywyere.
The psu.log file is attached.
jedavis Thu, 06/18/2009 - 09:15
That is what I am trying to do - update LibSwim to 1.8.7. If you look at the output of the psucli command in my original post you will see that it won't install because of a dependency on SharedSwimOpticalSwitch.
richard.tetu Tue, 07/28/2009 - 01:23
Hello Dears,
I have the same problem with RME 4.0.6.
The packages has been pushed from the download site of RME.
I have read the dependancies of the packages which should be installed and i have respect the installation sequence.
Martin Ermel Tue, 07/28/2009 - 05:16
what are your temp and tmp variable settings?
Login to your windows mashine then issue the DOS "set" command and post the output.
jedavis Tue, 07/28/2009 - 11:43
I discovered that the SharedSwimOpticalSwitch package is not installed as an independent package, but is installed along with one of the CW apps. I can't remember which one, my guess is Common Services. You need the latest CS version which is 3.0.6 under LMS 2.6.
richard.tetu Tue, 09/01/2009 - 06:39
Hello, dears all,
I afford to enter on this thread with my temp and tmp values given by the command set.
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrateur>set
AdminEmail=[email protected]
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Administrateur\Application Data
CLIENTNAME=EXBG02G
ClusterLog=C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=SPMLBFRLMS01
ComSpec=C:\WINDOWS\system32\cmd.exe
CWMIBDIR=d:\cwlms\objects\share\mibs
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Administrateur
LDMS_LOCAL_DIR=C:\Program Files\LANDesk\LDClient\Data
LM_LICENSE_FILE=d:\cwlms\objects\smarts\conf\trial.dat.DFM
LOGONSERVER=\\SBDADC1
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=d:\cwlms\campus\bin;d:\cwlms\objects\smarts\lib;d:\cwlms\objects\smarts\bin;d:\cwlms\MDC\tomcat\bin;d:\cwlms\MDC\Apache;d:\cw
lms\MDC\jre\bin;d:\cwlms\MDC\bin;d:\cwlms\lib\jre\bin\server;d:\cwlms\objects\db\win32;d:\cwlms\bin;C:\WINDOWS\system32;C:\WINDOWS
;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\WindowsPowerShell\v1.0;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 1, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0401
PROMPT=$P$G
SESSIONNAME=RDP-Tcp#3
SM_BROKER=spmlbfrlms01:9002
SM_HOME=d:\cwlms\objects\smarts
SM_RULESET_PATH=d:\cwlms\objects\smarts\rules
SM_SITEMOD=d:\cwlms\objects\smarts\local;d:\cwlms\objects\smarts
SM_SNMP_BUG_COMPATIBLE=1
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\ADMINI~2\LOCALS~1\Temp\1
TMP=C:\DOCUME~1\ADMINI~2\LOCALS~1\Temp\1
USERDNSDOMAIN=FR.SUB
USERDOMAIN=ZF
USERNAME=Administrateur
USERPROFILE=C:\Documents and Settings\Administrateur
windir=C:\WINDOWS
Thanks by advance.
