IOS Upgrade
Answered Question
Jun 17th, 2009
i'm in the process of upgrading a switch and ever time i try to copy the file over this is what i get.Can you tell me what might cause this
RTR1#copy tftp flash:
Address or name of remote host []? 10.2.X.X
Source filename []? cbs30x0-ipbase-mz.122-50.SE1.bin
Destination filename [cbs30x0-ipbase-mz.122-50.SE1.bin]?
Accessing tftp://10.2.X.X/cbs30x0-ipbase-mz.122-50.SE1.bin...
Loading cbs30x0-ipbase-mz.122-50.SE1.bin from 10.2.X.X (via Vlan5): !!!!!!!!!!!!... [timed out]
%Error reading tftp://10.2.X.X/cbs30x0-ipbase-mz.122-50.SE1.bin (Timed out)
Correct Answer by Leo Laohoo about 7 years 11 months ago
That's right. Just substitute the "file name" with the correct value. :)
Overall Rating: 4 (1 ratings)
garytayl Wed, 06/17/2009 - 08:40
  • Silver, 250 points or more
First make sure you can ping from TFTP server to the switch and the other way around.
If that works then make sure the image is in the root of the TFTP (name of the image is case sensitive, make sure is exactly the same).
Also, check that the TFTP has the send and receive options properly configured.
Hope it helps....
greg.washburn Wed, 06/17/2009 - 09:16
The file is starting then timing out.
You probably don't have enough room in flash.
Try this:
"dir flash:"
verify you have enough free space
If not enough do this:
"delete flash:'name of older ios or unused files'"
scooter817 Wed, 06/17/2009 - 09:18
you know that was the first thing that i check,the file is 8MB and i have 24MB free
greg.washburn Wed, 06/17/2009 - 09:25
Hmmm. then I'm sorta stumped as to what would cause the file to start copying over then stop unless maybe the flash is corrupted or has a bad disk area
"fsck flash:" maybe?
scooter817 Wed, 06/17/2009 - 12:30
Ok Greg
I figured out what it was,i have to have udp high ports enabled so that the bin file would load properly.But now i have one more question.now i have to make the new bin that i've load the perferred choice upon next boot with the old bin as back up.What commands do i need to enter to do this.
Leo Laohoo Wed, 06/17/2009 - 15:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Go to configure mode:
no boot system flash:
boot system flash:
boot system flash:
scooter817 Wed, 06/17/2009 - 16:33
so what i should do is get into config mode and do this
RTR#config T
RTR(Config)boot system flash:file name
Correct Answer
Leo Laohoo Wed, 06/17/2009 - 17:41
  • Hall of Fame,
    2017 LAN, Wireless
Leo Laohoo Wed, 06/17/2009 - 22:06
  • Hall of Fame,
    2017 LAN, Wireless
Happy to see it works. Thanks for the rating.
