ROMMON upgrade
Answered Question
Jun 17th, 2009
  • Purple, 4500 points or more
All,
When should you upgrade rommon? I've never done an upgrade, and I've only upgraded the IOS.
John
Correct Answer by Jon Marshall about 7 years 9 months ago
John
Put simply, when you need to. If you don't need to upgrade the ROMMON to run the software you want to run then leave well alone :-)
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 06/17/2009 - 08:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
Jon
John Blakley Wed, 06/17/2009 - 08:48
That's what I figured :)
Thanks!
John
Leo Laohoo Wed, 06/17/2009 - 14:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
The new IOS, 12.4(50)SE series and later, will upgrade the switch's ROMmon to 12.2(44)SE5 (so you don't have a choice whether you want to upgrade the ROMmon or not).
Depending on the routers, I would take advantage of upgrading 1800, 2800, 3800 because there is one major feature I want: USB Boot
Otherwise, I'd follow the old adage: If it ain't broke, doooooooooooooooooooon't fix it.
Hope this helps.
