Tunnel is up --> no traffic is passing
Answered Question
Jun 17th, 2009
I have built an ipsec L2L tunnel between the outside interfaces of a pix 515 (7.2.1) and an asa 5520 (8.0.2). I want the inside network of each firewall to be able to communicate with each other through the tunnel, but I cant get any traffic to pass through.
I have configured the nat (inside) 0 access-list nonat on each firewall with the traffic I want to pass through the tunnel and that acl also matches on my crypto map. The only way I can get the tunnel up is to ping my outside interface of each firewall (which I have added as "interesting" traffic) to get the tunnel up.
Any ideas of why my internal lans are not comunicating would be appreciated.
Correct Answer by auraza about 8 years 1 week ago
Remove the second line from access-list 160, and then add the following line to both PIX and ASA:
management-access inside
If you are trying to initiate traffic from the ASA, then you need the management-access command, however, it should come up if you try from a device on the inside network.
Overall Rating: 5 (2 ratings)
auraza Wed, 06/17/2009 - 09:14
  • Cisco Employee,
Can you post the configuration of both devices?
mcroberts Wed, 06/17/2009 - 09:57
Here is fw1
hostname ASA-01
interface GigabitEthernet0/0
speed 100
duplex full
nameif int
security-level 100
ip address 10.14.60.4 255.255.255.0 standby 10.14.60.5
interface GigabitEthernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.14.175.1 255.255.255.0 standby 10.14.175.2
same-security-traffic permit inter-interface
access-list 160 extended permit ip 10.14.175.0 255.255.255.0 192.168.175.0 255.255.255.0
access-list 160 extended permit ip host 10.14.60.4 host 192.168.60.4
access-list ib extended permit ip any any
access-list inside extended permit ip 10.14.175.0 255.255.255.0 192.168.60.0 255.255.255.0
access-list inside extended permit ip 10.14.175.0 255.255.255.0 192.168.175.0 255.255.255.0
access-list inside extended permit ip 10.14.175.0 255.255.255.0 10.14.60.0 255.255.255.0
access-list nonat extended permit ip 10.14.175.0 255.255.255.0 192.168.175.0 255.255.255.0
global (int) 1 10.14.60.200-10.14.60.250 netmask 255.255.255.0
nat (inside) 1 10.14.175.0 255.255.255.0
static (inside,int) 10.14.60.8 10.14.175.8 netmask 255.255.255.255
static (inside,int) 10.14.60.9 10.14.175.9 netmask 255.255.255.255
static (inside,int) 10.14.60.10 10.14.175.10 netmask 255.255.255.255
static (inside,int) 10.14.60.11 10.14.175.11 netmask 255.255.255.255
static (inside,int) 10.14.60.12 10.14.175.12 netmask 255.255.255.255
static (inside,int) 10.14.60.13 10.14.175.13 netmask 255.255.255.255
static (inside,int) 10.14.60.14 10.14.175.14 netmask 255.255.255.255
static (inside,int) 10.14.60.60 10.14.175.60 netmask 255.255.255.255
static (inside,int) 10.14.60.61 10.14.175.61 netmask 255.255.255.255
static (inside,int) 10.14.60.70 10.14.175.70 netmask 255.255.255.255
access-group ib in interface int
access-group inside in interface inside
route int 0.0.0.0 0.0.0.0 10.14.60.1 1
service resetoutside
crypto ipsec transform-set trans esp-aes-192 esp-md5-hmac
crypto map inside 10 match address 160
crypto map inside 10 set peer 192.168.60.4
crypto map inside 10 set transform-set trans
crypto map inside 10 set security-association lifetime seconds 10800
crypto map inside interface int
crypto isakmp enable int
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash md5
group 2
lifetime 86400
tunnel-group 192.168.60.4 type ipsec-l2l
tunnel-group 192.168.60.4 ipsec-attributes
pre-shared-key *
prompt hostname context a
mcroberts Wed, 06/17/2009 - 09:59
Here is fw2
PIX Version 7.2(1)
hostname insideFW-01
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address 192.168.60.4 255.255.255.0 standby 192.168.60.5
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 99
ip address 192.168.175.1 255.255.255.0 standby 192.168.175.2
access-list inside-IB-new extended permit ip 192.168.175.0 255.255.255.0 10.14.175.0 255.255.255.0
access-list inside-IB-new extended deny ip any any log
access-list outside-IB-new extended permit tcp host 164.185.38.225 object-group inside-outside-SVR eq 4253
access-list outside-IB-new extended permit icmp any 192.168.60.0 255.255.255.0 echo-reply
access-list outside-IB-new extended deny ip any any log
access-list 160 extended permit ip 192.168.175.0 255.255.255.0 10.14.175.0 255.255.255.0
access-list 160 extended permit ip host 192.168.60.4 host 10.14.60.4
access-list nonat extended permit ip 192.168.175.0 255.255.255.0 10.14.175.0 255.255.255.0
mtu outside 1500
mtu inside 1500
mtu sam 1500
global (outside) 2 192.168.60.200-192.168.60.225 netmask 255.255.255.0
nat (inside) 2 192.168.175.0 255.255.255.0
static (inside,outside) 192.168.60.8 192.168.175.8 netmask 255.255.255.255
static (inside,outside) 192.168.60.9 192.168.175.9 netmask 255.255.255.255
static (inside,outside) 192.168.60.10 192.168.175.10 netmask 255.255.255.255
static (inside,outside) 192.168.60.11 192.168.175.11 netmask 255.255.255.255
static (inside,outside) 192.168.60.12 192.168.175.12 netmask 255.255.255.255
static (inside,outside) 192.168.60.13 192.168.175.13 netmask 255.255.255.255
static (inside,outside) 192.168.60.14 192.168.175.14 netmask 255.255.255.255
static (inside,outside) 192.168.60.41 192.168.175.41 netmask 255.255.255.255
static (inside,outside) 192.168.60.42 192.168.175.42 netmask 255.255.255.255
static (inside,outside) 192.168.60.43 192.168.175.43 netmask 255.255.255.255
static (inside,outside) 192.168.60.251 192.168.175.251 netmask 255.255.255.255
static (inside,outside) 192.168.60.250 192.168.175.250 netmask 255.255.255.255
static (inside,outside) 192.168.60.110 192.168.175.110 netmask 255.255.255.255
static (inside,outside) 192.168.60.111 192.168.175.111 netmask 255.255.255.255
static (inside,outside) 192.168.60.114 192.168.175.114 netmask 255.255.255.255
access-group outside-IB-new in interface outside
access-group inside-IB-new in interface inside
established tcp 80 0
established tcp 443 0
route outside 0.0.0.0 0.0.0.0 192.168.60.1 1
crypto map inside 10 set peer 10.14.60.4
crypto map inside interface outside
crypto isakmp enable outside
encryption aes-256
hash md5
group 2
lifetime 86400
tunnel-group 10.14.60.4 type ipsec-l2l
tunnel-group 10.14.60.4 ipsec-attributes
pre-shared-key *
Correct Answer
auraza Wed, 06/17/2009 - 10:06
  • Cisco Employee,
mcroberts Wed, 06/17/2009 - 10:44
I have never seen that command before. So - if I understand the command correctly, everything was correct. However, I could not test from the asa until that command was inserted?
Thank you.
auraza Wed, 06/17/2009 - 10:53
  • Cisco Employee,
That is correct.
This commands allows you to access the ASA's interface specified in the command over the VPN tunnel.
Also, when you're initiating a ping from the ASA going to the other side you should specify the interface you want it to sourt from, so suppose you want to ping a device on a remote network (e.g. 10.1.1.1), you want to do it as such:
ping inside 10.1.1.1
That way the traffic is initiated from the inside interface.
