Infinite loop
Answered Question
Jun 17th, 2009
Hey guys,
I have a question about a blast group.
currently we have a blast group at extension 100 that rings two phones connected to the blast group. If no one picks up after 30 seconds the call goes into the AA.
What my client wants is for the blast group to ring extension 100 forever until someone picks up or the caller hangs up.
The issue I see is if I set the blast group 'no answer' setting to 'none' then the individual VM for one of the two extension in the blast group will pick up.
The only alternative I can see is to kill the VM boxes on the two phones in the blast group, but this wouldn't be an ideal situation as the individual users need their own VM.
Does anyone have a recommendation or is this just not possible?
Jorge
Correct Answer by Marcos Hernandez about 7 years 11 months ago
Yes you would, and that is just ugly. The dummy ephone-dn should do the trick then.
Marcos
Correct Answer by Skyler Spence about 7 years 11 months ago
You could try having the blast group call forward no answer to a dummy ephone-dn that is set to call forward always back to the blast group.
Overall Rating: 5 (2 ratings)
Marcos Hernandez Wed, 06/17/2009 - 09:06
  • Blue, 1500 points or more
Why don't you increase the voice hunt-group timeout to the maximum (60000 seconds)? In practical terms, this is "forever".
Marcos
Correct Answer
Skyler Spence Wed, 06/17/2009 - 09:07
  • Bronze, 100 points or more
jorgediaz77 Wed, 06/17/2009 - 09:14
Skyler, that is actually a very clever idea!
Marcos,
I ran into this issue at another client when I tried something like this. Basically the local phones in the blast group have noan set up for 30 seconds which was causing the blast group to drop the call. Wouldn't I have to set the timeout for the noan on the extensions within the blast group to that same huge number?
Correct Answer
Marcos Hernandez Wed, 06/17/2009 - 09:18
Marcos
jorgediaz77 Wed, 06/17/2009 - 09:25
Hahaha, indeed :)
I went with the dummy DN and it works like a charm. Thanks guys!
