Call restricting on Gateway
Jun 17th, 2009
I have a Cisco 2851 acting as my voice gateway for all of our customers. One client has a CM on site that I do not have access to, and when he sends calls to me the calling number is not a DID that I gave him.
How can I reject the calls unless he gives sends me a proper DID that is on my system?
infosateng Wed, 06/17/2009 - 10:31
Thanks, but I think what I need is something different.
I have 100's of clients and thousands of phone numbers. Each has a dial-peer for incoming (from PSTN) calls.
When a call is going out to PSTN it uses our default pots dial-peer and if the clients phone system sends my router the correct phone number it uses its matching dial-peer.
Here is an example:
calprigw1#sh voic call stat
port called codec dial-peers
1/0:23.20 *8665008676 g729r8 3138116/998
The calling number matches dial-peer 3138116 and the called number matches the outgoing DP 998. This is a call I would accept. Sometimes though the client does not send me their actual DID, so it looks like this:
1/0:23.20 *5551234 g729r8 0/998
In this case the number 5551234 is not a valid number on my system, but the router still sends it out to the PSTN. I want to be able to block these calls.
Any ideas?
Paolo Bevilacqua Wed, 06/17/2009 - 10:59
What I wrote above.
The alternative, is a TCL script that checks validity of calling number using any criteria you set. If you pay me for, I can write that for you.
infosateng Wed, 06/17/2009 - 11:12
I see what you are saying p.bevilacqua but how do I have my translation rule check all of the numbers on the router to confirm they are valid? I am talking about a list of 2000 valid phone numbers.
Do I write a rule for even phone number?
Cheers & Thanks,
Paolo Bevilacqua Wed, 06/17/2009 - 13:05
Agree it's much config, however using separated incoming voip DP and patterns in answer-address it might be doable.
Ah and that doesn't save you from the case where someone uses the calling number of another customer.
It's not that the router can have a magic way to know which calling number are valid and which are not.
infosateng Wed, 06/17/2009 - 13:09
Yeah I am not too worried about one client using another clients numbers, unlikely that will happen. It's more for those times when the client has a PBX on site and does not set it up well. Then when it comes to collecting CDR's and billing people end up with free long distance.
So for the answer-address would I put that on the voip DP's....or the pots? Hmmm?
infosateng Wed, 06/17/2009 - 13:49
Thanks, that seems like what I am looking for.....but!
I have a phone that when it calls out it sends the phone number 4035551234, not the actual number. If I change the VOIP dial-peer associated with it to include the line:
answer-address 4034511234
which is the actual phone number, then the call still ignores the DP and goes out like:
1/0:23.21 *4035434567 g729r8 0/998
So I don't see how this will help?
Paolo Bevilacqua Thu, 06/18/2009 - 01:26
It hits the default DP, you have to make the translations so that unless it hits the specific DP, the called number is invalid.
infosateng Thu, 06/18/2009 - 06:30
Ok so my calls hit the default DP, that I agree with.
But how do I make a translation rule say that if you don't hit your specific DP the call fails?
I am trying to block calls based on calling number, not called.
Cheers and Thanks!
Paolo Bevilacqua Thu, 06/18/2009 - 10:15
Like I said in my first reply.
When default DP is hit, no special prefix is added, and call will fail.
