SFP+ transceiver in 3750e
Answered Question
Jun 17th, 2009
Does anyone know if you can install an SFP+ transceiver (SFP-10G-SR) like a regular SFP (GLC-SX-MM)in the twingig module on a 3750e? or do you have to go with the x2 for 10Gb? thanks.
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Brandon,
according to
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/hardware/install/notes/1757202.html
is not supported so you need an X2 format module to replace the twingig module
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
bmarms Wed, 06/17/2009 - 10:30
that's what i thought, but wanted to verify. thanks.
iyde Wed, 06/17/2009 - 12:30
  • Silver, 250 points or more
Hi.
The Twingig is explicitly made to change an X2 10Gbps port to two 1 Gbps SFP ports, so no.
HTH.
