Backup CCM for desatry recovery
Afragoso2009
Does anyone cret a network folder to use as Network Backup devive on Callmanager ver 6?
With SFTP server it should be use ?
are you providing DNS name under server name field or ip address? If DNS, check CCM can resolve the name to ip address of the sftp server. you should specify \ as the path name so that it goes into the root of the sftp.
7 Replies 7
Jaime Valencia
The only options are:
•Archive backups to a physical tape drive or remote sftp server.
Disaster Recovery System Administration Guide for Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
Try FREEFtpd
java
if this helps, please rate
java
I agree with freeftpd. it is the best one I have seen for ftp and sftp. moreover it is free.
I am trying to find FREEFtpd but all the links apears to be broken
Someone cant share it with me?
Brgds
Hi Guys
I found it
But I am receiving the following error when I try to creat a device
"Unable to access SFTP server. Please make sure the login credentials and path are correct."
But allthi information is correct , even in the server I am seeing that The CCM connect to the server
Any help?
Yes I am using the IP
Specifying \ as the path name , solve the problem
Thaks a lot
no problem. good to hear it solved it.
