Change caller id of a specific phone
Answered Question
Jun 17th, 2009
CCM 5.1.3.
I would like to change the caller-id of a specific phones when he do a PSTN call.
I understand that I can do this with a route pattern..
is there any way to change it straight on the phone without playing with the CSS, just like changing the "party mask" or something like that
thanks
Correct Answer by Jaime Valencia about 8 years 1 month ago
You change the ANI you send in:
External phone party mask
Route pattern
Route list
GW
If you use the external phone party mask it changes it for any call that is made thru the RP with that checkbox
You can try using a translation pattern to modify the ANI as well.
In any case if this is only for a set of phones (or 1 phone) it requires you to play with CSS and partitions.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 06/17/2009 - 10:53
  • Cisco Employee,
  • Hall of Fame,
    2011
Route pattern
Route list
GW
java
