Problems with Home setup
Jun 17th, 2009
Lets start off by saying I'm not a voice guy. So my questions may be a bit novice.
Equip: 1760-V with vic-2fxs and -2fxo
Goal: Two POTS lines plugged into FXO card. 1 for the house, 1 for my office. Office has 7960g. House cordless system is plugged into FXS port. I want to be able to answer the home line from my 7960 or the FXS port.
What I've been told / looked into.
1. Configure FXS as SCCP controlled port using STCAPP. This is not supported on my router for some reason.
2. Configure a hunt-group in broadcast mode between the FXS and ephone-dn. I have no clue how to do this, and can't find any docs that show examples. (All the hunt groups I see are between ephones.. not FXS ports, or even mixed between them)
3. What I originally tried was just setting the same number/destination-prefix on both, this didn't work at all. Probably obvious for anyone that does this stuff day to day..
Any suggestions would be most appreciated. I really don't have the money to spend more money on a 2811 which IMHO would be HUGE overkill. The 1760 should be able to do this just fine.. just not sure how, or if its possible even.
Thanks again in advance.
-Tony
Overall Rating: 5 (4 ratings)
paolo bevilacqua Wed, 06/17/2009 - 10:49
  • Hall of Fame,
    Founding Member
Actually not an easy task.
1. you found already
2. pretty much same as 1
3. there is no native parallel ringing in IOS
Check the bcast.tcl service that I wrote, it is not fully tested anyway:
http://pbevila.fastmail.fm/public/
Tony Mattke Wed, 06/17/2009 - 11:09
Hmm, So my config will be below all of this... I want to ring pots line 55 and ephone-dn 50.. I assume I needed to assign a destination-pattern to the dial-peer even so it wasn't show in the tcl file.
When I attempt to dial extension 22 from my other pots line (ext 11). it just goes busy...
I get the following from debug.. not sure if that will help.
Mar 1 06:25:08.672: //-1/E715D995808B/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 1 06:25:08.676: //-1/E715D995808B/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=2
Mar 1 06:25:08.676: //-1/E715D995808B/DPM/dpMatchCore:
Dial String=2, Expanded String=2, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Mar 1 06:25:08.676: //-1/E715D995808B/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
application
service bcast flash:/bcast.tcl
param destinations 50,55
dial-peer voice 11 pots
destination-pattern 11
port 1/0
dial-peer voice 55 pots
destination-pattern 55
port 1/1
dial-peer voice 100 pots
service bcast
destination-pattern 22
ephone-dn 1
number 88
label Office
ephone-dn 2
number 50
label Home
ephone 1
description Anthony R. Mattke
mac-address 0017.94CF.1E45
type 7960
button 1:1 2:2
Let me know if there is anything I can do to help debug this. And thank you for the script, I hope we can get it working !!!
paolo bevilacqua Wed, 06/17/2009 - 11:22
  • Hall of Fame,
    Founding Member
Check the comments in the script
# description broadcast hunt-group
# service bcast
# incoming called-number 5551234
replace 5551234 with the number that you have as connection plat under fxo ports.
Tony Mattke Wed, 06/17/2009 - 11:26
Yeah, I just realized that. I don't have the FXO setup in my lab right now. Does this have to be incomming from the FXO ? I tried using incoming called-number 22 and dialing that from an FXS and it gives me the same no match.
paolo bevilacqua Wed, 06/17/2009 - 12:38
  • Hall of Fame,
    Founding Member
You want to learn script black magic too ?
Enable "debug call application script" with "term mon".
Tony Mattke Wed, 08/19/2009 - 12:36
So I finally got around to working on this again, and I can not get the script to work properly... I might be missing something here... My phone dials properly going out (altho, I can't dial more than 7 digits for some reason.. working on that later) When I dial into the Vonage line, I get a strange busy signal from the Cisco..
I appreciate your help, and really hope we can get this script to work with my setup!
This is the config...
trunk group OUT
voice register dn 1
application
voice-port 0/0
trunk-group OUT
connection plar 5742575555
description Vonage (home)
voice-port 0/1
trunk-group OUT
connection plar 88
description Office
voice-port 1/0
voice-port 1/1
description Home Phone
sccp local FastEthernet0/0
sccp
dial-peer voice 10 pots
port 1/0
preference 1
destination-pattern 55$
port 1/1
service bcast
incoming called-number 5742575555
dial-peer voice 1000 pots
trunkgroup OUT
description Local Calls
destination-pattern [2-9]......
forward-digits 7
dial-peer voice 1001 pots
trunkgroup OUT
description Long Distance
destination-pattern 1[2-9].........
forward-digits 10
dial-peer voice 1002 pots
trunkgroup OUT
description Long Distance 9
destination-pattern [2-9].........
forward-digits 10
dial-peer voice 1003 pots
description International
destination-pattern 011T
port 0/0
telephony-service
load 7960-7940 P00308010100
max-ephones 3
max-dn 24
ip source-address 10.1.8.1 port 2000
service dnis dir-lookup
cnf-file location flash:
cnf-file perphone
max-conferences 4 gain -6
moh music-on-hold.au
web admin system name admin secret 5
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Mar 01 2002 02:37:39
ephone-dn 1
number 88
label Office
call-forward noan 55 timeout 18
hold-alert 30 originator
ephone-dn 2
number 50
label Home
preference 1
ephone 1
description Office
type 7960
button 1:1 2:2
paolo bevilacqua Wed, 08/19/2009 - 12:50
  • Hall of Fame,
    Founding Member
The script doesn't work because this being an FXO, you have to match with "port" instead of "incoming called-number" under DP 100, so you can remove connection plar from port 0/0/0 and that should fix both issues.
Tony Mattke Wed, 08/19/2009 - 13:53
That works quite well, thank you so much for your help!
My next question, and hopefully my last for a while, is when I call the FXO line on my cell, and let it ring, say twice, after I hang up, it continues to ring my FXS port and my DN for an undetermined amount of time..
Is there some config I'm missing to make it stop ringing ?
paolo bevilacqua Wed, 08/19/2009 - 14:02
  • Hall of Fame,
    Founding Member
Yes, you would need configure disconnect supervision. But, you can easily work around the problem by adding "opx" to "connection plar".
Please remember to rate useful thread with the scrollbox below.
Tony Mattke Wed, 08/19/2009 - 14:34
So, I'm probably going to continue to sound really stupid here, but like I said, I'm not a voice guy...
I'm attempting to setup disconnect supervision, but everything I've tried seems to not work properly..
First try included
voice-port 0/0
trunk-group OUT
supervisory disconnect dualtone mid-call
supervisory answer dualtone
cptone us
no battery-reversal
timeouts call-disconnect 1
timeouts wait-release 1
I then tried something I saw about using a Comcast ATA
voice class custom-cptone TEST
dualtone disconnect
frequency 480 625
cadence 250 250
voice-port 0/0
trunk-group OUT
supervisory custom-cptone TEST
no battery-reversal
Anywhere you might be able to point me to explain how to set this up properly?
paolo bevilacqua Wed, 08/19/2009 - 14:51
  • Hall of Fame,
    Founding Member
I see, that happens with the script.
Can you please take the debugs I've indicated above? That would allow me to see if there is a way to make it behave like opx in plar. Also, you can configure "param alert-time xx" under service, to change the seconds before it gives up ringing.
Otherwise it would be needed to find out what is the disconnect tone used by Vonage and that can take some time.
Tony Mattke Wed, 08/19/2009 - 15:07
Hmm, I tried debugging before.. and I don't have the option you specified..
1760-VCME#debug call ?
fallback VoIP Fallback
filter debug about GCFM/GKFM
rsvp-sync QoS Module: RSVP/Voice Signaling Synchronization
threshold debug about resource measurement
treatment Call Treatment
Tony Mattke Wed, 08/19/2009 - 14:48
I'm sorry, I just looked into what you meant by OPX, and I setup that up and it seems to work, altho, I would like to know why the disconnect supervision wouldn't work still.. Could be interesting knowledge to have in the future if I ever have to set this up.
paolo bevilacqua Wed, 08/19/2009 - 15:08
  • Hall of Fame,
    Founding Member
Good to know my script rocks.
For disconnect, do a comparison by hear, call into pstn and vonage, answer on CME, caller hangs-up, do they sound the same ?
Tony Mattke Wed, 08/19/2009 - 17:11
I'll have to try that out in the future.. I don't have a pstn line here to test.
I do have even more questions though.. LOL
Ok, my dialplan I setup is as follows..
trunkgroup OUT
forward-digits 7
trunkgroup OUT
forward-digits 10
trunkgroup OUT
forward-digits 9
port 0/0
I haven't tried the international dialing, and I still need to add one for 911 services, but, my 9 digit dialing doesn't work... it forwards it out as 7 digits...
Also, on the 7960 phones, is there a way to get rid of the mac address on the screen?
Thanks again, You really are my hero !
Tony Mattke Wed, 08/19/2009 - 19:08
Ok, I solved my own dialplan issue.. Here is what I came up with...
trunkgroup OUT
destination-pattern 1?[2-9]..[2-9]......
forward-digits all
trunkgroup OUT
destination-pattern .T
forward-digits 7
port 0/0
And I changed the telephony service interdigit timeout to 3 seconds.
Works like a charm.
paolo bevilacqua Thu, 08/20/2009 - 03:53
  • Hall of Fame,
    Founding Member
In America, you need complete on timeout only for international, and 0 to operator (if someone still uses that).
So, local calls should be:
destination-pattern [2-9][0-9][0-9]....
You do not need any "forward digits" command with that, because digits in bracket are not absorbed by pots DP, a very useful property.
There is also another technique, define an access digit like 9, once you dial that you get dialtone from vondage, pstn or whatever, from there one you're dialing directly into their.
The evolution to this is that you eliminate the access digit altogether, and as you lift an extension you're cut-though to a pstn line. But, you can't call extensions this way.
I'm saying all these things becasue you said you wanted to learn...
Tony Mattke Thu, 08/20/2009 - 05:47
The only reason I was using the Timeout was so I could dial 10 or 11 digit long distance, were so used to it that it just comes natural these days..
Do you know if it is possible on the 7960 phone to remove the mac address from the top of the screen?
Thanks for the all the info, I really appreciate your help!
-Tony
paolo bevilacqua Thu, 08/20/2009 - 07:59
  • Hall of Fame,
    Founding Member
ephone-dn xx
description 555-1234
Thanks for the nice rating and good luck!
Tony Mattke Thu, 08/20/2009 - 12:09
I think I'm about togive up on this whole thing....
So, this morning, I'm able to call out just fine, but when people call my vonage line, it tells them I'm plugged into the wrong port. This is what I see on the router... 1760-VCME#show voice call sum
PORT CODEC VAD VTSP STATE VPM STATE
0/0 - - - FXOLS_WAIT_RING_MIN
0/1 - - - FXOLS_ONHOOK
0/0 - - - FXOLS_RINGING
0/0 g711ulaw n S_PROCEEDING FXOLS_PROCEEDING
0/1 g711ulaw n S_SETUP_REQ_PROC FXOLS_WAIT_DIAL_TONE
Here is where it gets all kinds of strange.
1. I switch ports, I can no longer call out (says wrong port) but people can call in.. AND my phones no longer ring at the same time. It rings my ephone for a few, and THEN rings my FXS. My CME box shows the call ringing on the wrong line.. Which is why it behaves that way when ringing.. I have the port that isn't even plugged in configured to ring my office phone, then the house phone after so many seconds..
0/0 - - - FXOLS_ONHOOK
0/1 g711ulaw n S_ALERTING FXOLS_PROCEEDING
2. I switch to a 2 wire phone cord (Vonage's advice.) Nothing rings, no error, I'm able to call out. And I see this on the router.
0/0 - - - FXOLS_GUARD_OUT
3. I hook up an anlog phone direct to the vonage box, and everything works fine...
4. 2 wire cord in the wrong (2nd) vonage port, no error, nothing ONHOOK on the router. No ring.
I'm at a loss... I'm not sure what I need to configure to make this work at all..
Tony Mattke Fri, 08/21/2009 - 07:42
So, this morning I switched everything from using voice-port 0/0 to 0/1 and it seems to work again, apparently my FXO port died in the middle of the night? Its strange though, because the router still seems to realize its rining, it just doesn't do anything with it...
Anyway, let me know if you know how to get rid of that mac address on the upper left corner and i'll probably be out of your hair for a while, at least until I figure out if I can support caller id / vic 2fxo modules...
-Tony
Tony Mattke Thu, 08/20/2009 - 12:40
In addition to the huge problem I'm now having.....
I had already set the description, and the top row showed my name on the right, but the mac adddress on the left hand side...
