VSS - Dual active
Jun 17th, 2009
Dear Friends,
If i have to specify PAGP as the Dual-active handling mechanism and two port channels as trusts for dual active detection, is this the way i need to configure them:
dual-active detection pagp
dual-active trust channel-group 11
dual-active trust channel-group 12
Thanks a lot
Gautam
Rahul Kachalia Wed, 06/17/2009 - 17:14
Yes, that is correct configuration. Make sure switch connected to EtherChannel 11 and 12 supports ePAgP...
thanks,
rahul.
