LAPC on 6509 fails
Jun 17th, 2009
Hi, I keep running into a problem with my 6509 when I try to setup a 4x LACP connection between my server and my switch on copper ports. I can get this to work with my fiber ports.
The problem that I see is that the 6509 adds
after I connect the server to the 6509.
Here is my port-channel before I connect the server
interface Port-channel3
no ip address
switchport
switchport access vlan 261
switchport mode access
end
Here is my port-channel after I connect the server
no ip address
switchport
end
Here is a sample of 1/4 of the gig ports that uses this port-channel
interface GigabitEthernet4/40
no ip address
switchport
channel-group 3 mode active
end
Does anyone know why my 6509 keeps on adding " switchport trunk encapsulation dot1q" into the port-channel's config after I connect the server to the 6509? and how I can fix this?
I do not have this problem on the same 6509 with my fiber gig ports.
I have also read and tried the example from this website: http://supportwiki.cisco.com/ViewWiki/index.php/EtherChannel_Between_a_Cisco_Catalyst_Switch_That_Runs_Cisco_IOS_and_a_Workstation_or_Server_Configuration_Example
and it has not helped in trying to solve this problem
Thanks in advance
Joe
iyde Wed, 06/17/2009 - 21:28
Hi Joe.
Is the problem that it does not work or is it that you see the 'switchport trunk encapsulation dot1q' in your config?
I beleive that the switch just adds the line about the encapsulation by default to show what encapsulation would be used if the port at some time should be reconfigured from access port to trunk port.
HTH.
josephninan Thu, 06/18/2009 - 05:15
HTH, Thanks for asking, The problem is that on the copper ports I can only get about 1gig worth of bandwidth accross 4x ports. With the fiber ports (without the trunk encapsulation) I get about 4gigs worth of bandwidth. The only difference between the two configs is the addation of the "switchport trunk encapsulation dot1q" on the copper port port-channel's config.
Jon
You were exactly right with the restrictions. It looks like I was running into an oversubscription problem with my port/blade setup.
Once I spaced out my ports to 4/1, 4/9, 4/17, 4/25
I was able to get my bandwidth up to about 74% of 4gig.
Again thank you very much for your help and support in helping me trouble shoot this problem.
--Joe
