DHCP on subinterface
Answered Question
Jun 17th, 2009
Can anyone tell me if it is possible to create 2 seperate DHCP pools on 2 subinterfaces. The reason I am asking is because I want to create a router on a stick with seperate DHCP pools. Thanks in an advance.
Correct Answer by Jon Marshall about 8 years 1 month ago
Bart
Yes, there is no problem with this. Either you can have separate ip helper-addresses under each subinterface or you can configure multiple DHCP pools on the router, one for each subinterface.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 06/17/2009 - 14:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bart
Jon
bsudol79p Wed, 06/17/2009 - 14:22
thanks a lot for your help. I just don't have a free router at the moment in order to test it but you got me the answers I needed. Thanks
Jon Marshall Wed, 06/17/2009 - 14:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No problem, glad to have helped.
Jon
