SNR Desk Phone and Cell do not ring simultaneously
Jun 17th, 2009
  • Bronze, 100 points or more
I've setup Unified Mobility (Single Number Reach) successfully on our internal cluster. Now, I'm trying to get it going on a 7.0(2) customer cluster. It appears to be configured correctly, but when I call the DN, it rings for a second or so, then stops when the call goes to the cell phone. It will not ring both at the same time. Any ideas?
Thanks!
Anonymous (not verified) Fri, 06/19/2009 - 03:36
jmunoz19 Sat, 06/20/2009 - 11:39
I just tried that and it didn't help. The system does not want to ring both calls at the same time; it rings the desk line, then the button turns red and it sends the call to the mobile phone. Once the button turns red, you cannot pick it up on the desk phone and the mobile phone starts to ring.
Any idea why it's not ringing both devices at the same time?
Thanks!
Jeff
Jonathan Schulenberg Fri, 07/10/2009 - 18:06
  • Cisco Designated VIP,
    2017 IP Telephony
This is most likely because UCM thinks you answered on the cell phone. I would debug the gateway and see if the call is connecting prematurely. Make sure you have a supported PSTN interface for Mobile Connect. If you do, you'll probably need to work with the telco to figure out why they (or more likely the cellular carrier) is not signaling properly.
