110001: No route to
fredericmoitie
first time, sorry for my english.
so i explain my problem.
i have An ipsec vpn with 2 pix 515 and a router on 1 of this site.
lan_a-->Pix_a--ISP--Pix_b<--Lan_b<--router<--Lan_b2
traffic for lan_a and lan_b, no problem.
traffic for lan_b and lan_b2, no problem
but traffic lan_b2 and lan_a don't work,
i have a route inside in my pix_b.
but i have a stange comportement, because ping was work,
but other traffic don't work, example, when i want telnet on port 25 in lan_a since lan_b2, i have an error in pix_b log
anyone can help me ?
tahnks
23 Replies 23
fredericmoitie
hello
more detail
in pix log, i have an error
110001 no route to x.x.x.x from y.y.y.
x was in lan_b2
y was in lan_a
thanks
Which pix is this error message showing up on, is it pixb ?
If so can you
1) post output of "sh route" from pixb
AND
2) specify the IP subnet of lan_b2
Jon
Hello jon
Thanks for your reply.
yes, error message on pixb
see sh route on pixb
pixb# sh route
outside 0.0.0.0 0.0.0.0 217.108.xx.xx 1 OTHER static
DMZ 10.10.10.0 255.255.255.0 10.10.10.254 1 CONNECT static
inside 10.10.30.0 255.255.255.0 172.22.56.1 1 OTHER static
inside 172.22.56.0 255.255.255.0 172.22.56.8 1 CONNECT static
outside 217.108.xx.xx 255.255.255.240 217.108.xx.xx 1 CONNECT static
pixb#
subnet of lanb_2 as 10.10.30.0/24
subnet of lanb as 172.22.56.0/24
subnet of lana (remote vpn) as 172.22.57.0/24
error message as :
no route to 10.10.10.38 from 172.22.57.16
thanks
fred
Someone help me, please.
Frederic
Fred
Apologies for the delay in getting back to you.
Could you just clarify ie.
from your routing table -
error message -
which is the correct subnet ie.
your route is for 10.10.30.x but the error message is about 10.10.10.x ?
Jon
Jon,
Oups, sorry, that an error when i write this post.
the real error message as :
no route to 10.10.30.38 from 172.22.57.16
sorry,
thanks
Frederic
Fred
which device is 172.22.57.16 ?
Can you post configs of both firewalls ?
Jon
Hello
172.22.57.16 as a mail server
in attachement :
Config of firewall pix a
Config of firewall pix b
Config of router b
in same file
"Conf Pix A, Pix B, Router B .txt"
and Network map
i have delete all information you don't need in config (password, IP public, etc..)
Many thanks for your help.
Frederic
Hello Jon,
As you can see my problem ?
Frederic
Frederic
From pix b can you ping 10.10.30.38 ?
Jon
Jon,
Yes i can.
Pix_b# ping 10.10.30.38
10.10.30.38 response received -- 0ms
Pix_b#
and since pix_a too (that strange)
Pix_a# ping inside 10.10.30.38
10.10.30.38 response received -- 40ms
10.10.30.38 response received -- 30ms
Pix_a#
but when i want make an telnet (for example) since 10.10.30.38 to 172.22.57.xx (Lan_a), don't work
i don't understand, because there are no acl was block this traffic, and ip route are ok
Frederic
Frederic
Could you clarify. Are you trying to telnet to 172.22.57.x from 10.10.30.38 ?
If so there may be an issue with your config on pix b. You have this applied to your inside interface on pix b -
access-list inside_access_in permit ip 172.22.56.0 255.255.255.0 any
is this a typo as you have the same line twice. You will need the following line in that acl as well
access-list inside_access_in permit ip 10.10.30.0 255.255.255.0 any
Jon
Jon,
exactly, i try telnet 172.22.57.16 (it's a mail server) from 10.10.30.38
yes, is a typo.
my real acl as :
access-list inside_access_in permit ip All-Lan 255.255.255.0 any
object-group network All-Lan
network-object 172.22.56.0 255.255.255.0
network-object 10.10.30.0 255.255.255.0
Frederic
Frederic
Can you run some tests -
1) From mail server 172.22.57.16 can you ping 10.10.30.38 ?
2) From 10.10.30.38 can you ping 172.22.57.16 ?
Jon
