VS-S720-10G port channel error disable(not vss mode)
Jun 17th, 2009
hi
i have 2 x c6509e, each equiped with 1 x VS-S720-10G(with 2 x 10g port), i need to confiure portchannel with both 10g port between this two c6509e, and need to use standalone mode only(not VSS), however i found error disable from one side of switch after enabled the portchannel from 10g port,
i checked all fiber cable work fine, if not use portchannel configure, i can bring up both 10g port those switches,
here's the port channel configure(identical from both c6509e):
interface Port-channel1
switchport
switchport trunk encapsulation isl
switchport mode trunk
interface TenGigabitEthernet5/4
switchport
channel-group 1 mode on
interface TenGigabitEthernet5/5
switchport
IOS Version 12.2(33)SXH4
Giuseppe Larosa Thu, 06/18/2009 - 00:40
  • Hall of Fame,
    Founding Member
Hello Tat,
try to use 802.Q encapsulation
may you post the error message you can find it with
sh log
Hope to help
Giuseppe
tatsun Thu, 06/18/2009 - 04:48
i do not know what is happen, but after upgrade to 122-33.SXH5.bin, the portchannel is work fine for 10g port,thanks!
