How to configure BRI in CCME point to multipoint
Answered Question
Jun 18th, 2009
I've a CCME with 2 bri, ISDN line is point to multipoint, what is command for solved my problem ?
Thanks all
Dario
Correct Answer by paolo bevilacqua about 7 years 10 months ago
12.4(4)XJ4 is rock stable, but not very recent.
Else take a pick from recent 12.4 T
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 06/18/2009 - 00:59
  • Hall of Fame,
    Founding Member
That is the default configuration and no command is needed.
Only, recommend you use "isdn tei-negotiation preserve".
dpirovan Thu, 06/18/2009 - 02:57
I've use "isdn tei-negotiation preserve" but this is isdn error when try to call.
003230: *Jun 18 12:55:47.731 Berlin: ISDN BR0/0/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 127 ces 0 ev 0x250
003231: *Jun 18 12:55:51.727 Berlin: ISDN BR0/0/0 SERROR: L2_Go: at bailout DLCB is NULL
003232: *Jun 18 12:55:51.727 Berlin: ISDN BR0/0/0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0x8016, event 0x95 ces 0
003233: *Jun 18 12:55:51.727 Berlin: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event received for an unrecognized call. Data- 95, 0
paolo bevilacqua Thu, 06/18/2009 - 03:07
  • Hall of Fame,
    Founding Member
Likely buggy IOS, upgrade to something else.
Correct Answer
paolo bevilacqua Thu, 06/18/2009 - 04:33
  • Hall of Fame,
    Founding Member
dpirovan Wed, 06/24/2009 - 05:08
Now I have install c2801-advipservicesk9-mz.124-19.bin when try to call error is :
"000365: .Jun 24 14:06:53.899: ISDN BR0/0/0 **ERROR**: CC_CHAN_GetIdleChanbri: All channels busy"
paolo bevilacqua Wed, 06/24/2009 - 11:23
  • Hall of Fame,
    Founding Member
Try what I've indicated above that works for sure. Then you will have time to upgrade.
dpirovan Tue, 07/07/2009 - 08:40
Now IOS is 12,4 (4) XJ4 but not call in or out.
Debug Isdn Error:
001801: *Jul 7 17:35:24.971: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x650
001802: *Jul 7 17:35:25.007: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x3
001803: *Jul 7 17:35:26.971: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
001804: *Jul 7 17:35:27.011: ISDN BR0/1/0 SERROR: L2_Go: at bailout DLCB is NULL
Have you an idea ?
paolo bevilacqua Tue, 07/07/2009 - 09:36
  • Hall of Fame,
    Founding Member
bad, does the line work with an ISDN telephone ?
dpirovan Thu, 07/09/2009 - 23:21
yes work fine, probably i've bad configuration ?
paolo bevilacqua Fri, 07/10/2009 - 03:45
  • Hall of Fame,
    Founding Member
Post it here.
dpirovan Fri, 07/10/2009 - 05:10
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname CCME
boot-start-marker
boot system flash c2801-spservicesk9-mz.124-11.XJ4.bin
boot-end-marker
no logging buffered
enable secret 5 $1$h43y$TxrNu.aYqXMARAaO9Ue1q/
no aaa new-model
clock timezone Berlin 1
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
network-clock-participate wic 0
network-clock-participate wic 1
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.79
ip dhcp excluded-address 10.0.1.86 10.0.1.254
ip dhcp pool Pool
import all
network 10.0.1.0 255.255.255.0
dns-server 10.0.1.9 10.0.1.19
option 150 ip 10.0.1.4
ip telnet source-interface FastEthernet0/0
no ip ftp passive
ip name-server 10.0.1.9
ip name-server 10.0.1.19
ip ssh time-out 60
ip ssh authentication-retries 2
isdn switch-type basic-net3
voice-card 0
voice translation-rule 1
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1
username admin password 7 08374342080B00
ip address 10.0.1.4 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
description Voce
no ip address
isdn incoming-voice voice
interface BRI0/0/1
no ip address
isdn point-to-point-setup
interface BRI0/1/0
description GSM
no ip address
interface BRI0/1/1
no ip address
ip route 0.0.0.0 0.0.0.0 10.0.1.253
ip http server
ip http secure-server
control-plane
voice-port 0/0/0
compand-type a-law
description Voce
voice-port 0/0/1
voice-port 0/1/0
compand-type a-law
description GSM
voice-port 0/1/1
dial-peer cor custom
dial-peer voice 1 pots
description Dial Plan
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
destination-pattern 0T
port 0/0/0
prefix 0
dial-peer voice 2 pots
destination-pattern 3T
port 0/1/0
prefix 3
telephony-service
max-ephones 25
max-dn 25
ip source-address 10.0.1.4 port 2000
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
web admin system name admin secret 5 $1$CP/9$Cvy85UASAsPl6CpjIwNNI1
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 24 2009 14:34:43
ephone-dn 1 dual-line
number 930
label Dario
name Dario Pirovano
ephone 1
username "dpirovano"
mac-address 0023.331A.6644
type 7960
button 1f1
line con 0
line aux 0
line vty 0 4
privilege level 15
password 7 07192E404F1B1C
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.0.1.9 source FastEthernet0/0 prefer
ntp server 172.22.1.107 source FastEthernet0/0
end
paolo bevilacqua Fri, 07/10/2009 - 05:18
  • Hall of Fame,
    Founding Member
Config is correct. You only would need
network-clock-select 1 bri 0/0/0
but that probably will not change anything.
I don't know what to think, sorry.
