Cisco 877 erase startup config
Jun 18th, 2009
Hello!
After power off Cisco 877 erase startup config. This is output from console:
"Erasing the nvram filesystem will remove all files! Continue? [OK] Erase of nvram: complete Router IOS Configuration Recovery is unsuccessful"
After that it reloaded with empty config.
If I reload it from console or telnet, everything OK.
is anybody faced this problem?
Giuseppe Larosa Thu, 06/18/2009 - 10:47
Hello vladimir,
you have erased = deleted the configuration file so it is expected to start with an empty configuration file
answer n = no to the question
Hope to help
Giuseppe
