Database is currently not online
Jun 18th, 2009
Dears,
in the operations console of CVP, when opening the database details of the informix, the
customer get the attached screenshot.
the onstat- command shows that the informix database is online,
the reporting server is showing up in the operations console, both the operations console
and reporting servers has been restarted with no problem resolution.
Please advise,
david.macias Thu, 06/18/2009 - 05:17
  • Blue, 1500 points or more
Can you ping the IP from the Ops Console server? Have you verified that reporting server actually works? I've noticed that to clear some of these problems is usually best to just delete the currently configured device and start from scratch.
david
fabien.damien Thu, 06/18/2009 - 05:33
Hi David,
Thanks for your reply i think the third option is the best i'll try it and get back to you to see if it resolves the problem.
Thanks again,
fabien.damien Fri, 06/19/2009 - 02:50
Hi David,
removing the reporting server from the console and adding it again didn't solve the problem any alternatives?
thanks for your help,
