I want your valuabale opininon on ESW 500 series switches
Jun 18th, 2009
In my offiec i want to connect 8 accesspoints and 8 smart boad and 8 pcs to a switch the access points are cisco 1240g series and controlled by a wlan controller.
this switch should be connected to a core switch 4507 using fiber.
can i use these esw switches for this
Maulik Shah Thu, 06/18/2009 - 10:54
Not sure what you mean by 8 smart boad - can you be more clear on that?
Couple of comments:
- Please note that we recommend the ESW in a Cisco Small Business type deployment with products such as UC500, SR500, AP500. Also, management is via a configuration utility GUI or CCA, not CLI as you would use for the Cisco Catalyst switches. Check this discussion which has a PDF that goes over positioning of the switches- https://www.myciscocommunity.com/message/8385#8385
- Please check the POE requirements you need against the ESW switches - check the question on at Q & A
Q. How many devices can the Cisco ESW 500 Series PoE switches power?
nasilpanambron Thu, 06/18/2009 - 23:44
we wwnt to connect projectors also  with smart board capable
pls help me regarding this
when we configure multiple vlans on esw switch and want to get ip through dhcp for this devices through a external dhcp.that is for each vlan differnt subnets
how it can be configured
Maulik Shah Fri, 06/19/2009 - 10:18
Not sure I follow what projectors with smart board imply but I assume they are IP devices and may need POE. The simple approach would be:
- Logon to the web gui of the ESW
- enable VLANs that you need on the switch
- tag each port as a Desktop Smartport role and define the right vlan for each port depending on your requirement
See the getting started section of the admin guide at link below:
http://www.cisco.com/en/US/docs/switches/lan/csbms/esw500/administration/guide/ESW_500_Administration_Guide.pdf
