Unity Connection and Unity - VM to IMAP client vs VM notification
Jun 18th, 2009
Hello All,
I have a question regarding the use of the VM notification from unity personal assistant and recieving the vm in your email using an imap client via unity connection.
With the IMAP client connected to the exchange server and VM notifications turned on, will a user always recieve two emails. One being the notification and one being the VM? When there IMAP client is turned off they will always recieve a notification correct, such as to there blackberry? Thanks
Tommer Catlin Thu, 06/18/2009 - 13:41
  • Green, 3000 points or more
With CUC, the notification is still sent the the SMTP address that was configured in the profile or CUC smtp relay. Basically, the message can be sent as attachment to a designated address (relied) or notification sent out there is a new voicemail, or like you see, IMAP client is open, the message is sync'd to the client.
