CRA Calling Queue
Jun 18th, 2009
I am currently working with a Call Manager system along with CRA. My goal is to have incoming calls routed to a queue after an option is selected from a caller. I realize that we need a CTI port group connection from CRA to Call Manager to make this work. Someone else had set the system up originally and now I am having to get into the CRA system through a backdoor by renaming the cnndir.ini file. This will allow us to access the Administration panel with the default username and password.
When I select the JTAPI option under Subsystems in the CRA panel, I go to create a CTI port group connection and get an error. I have also noticed that other portions of the panel have similar JAVA errors, which I have posted below.
The error reads the following:
Error: 500
Internal Servlet Error:
Then there are multiple lines of errors below that. I have added an attachment for further information.
My question is by renaming the cnndir.ine file, is there a link with the error? How can this issue be resolved.
dennisbehrens Thu, 06/18/2009 - 09:46
I see that you're running CM 4.1. Are you running IPCC 4.0? I'm pretty confident that renaming cnndir.ini could break the ability to create a new JTAPI resources.
Did you follow the entire process listed in Solution 1:
If my memory serves me correctly, after completing these steps, IPCC should have to go back through the Cluster Setup. The cluster setup should rebuild your cnndir.ini file.
livewire101 Thu, 06/18/2009 - 10:31
Thanks for the link. Unfortunatly I have tried this and was unsuccessful after making the changes. Is there some sort of tool to try to recover the original password?
The version for CRA is 3.5(4). I forgot to mention that this is a live system that controls 3 different physical locations. So any mods must not bring them down.
