ACS 4.2 SE RDBMS syncronisation - accountActions csv file
Jun 18th, 2009
Hi All
I am currently deploying a couple ACS SE 4.2s to which I have to import a load of users/NDGs via RDMBS synchronisation using the accountActions.csv file.
Issue is I find the documentation quite confusing and no examples as to what the csv should look like.
As I dont have that much time to go at this trial and error ;-) I was wondering if anyone has done this - and could post a snipet of the csv file that worked for the Network Device Group import?.
Many thanks.
dpatkins Thu, 06/18/2009 - 10:07
I have attached a file that shows how to do this. The first set of statements (action 220) adds the devices and then the second action (action 250) adds the NDG and the last set, 252 added the first set of devices to the NDG.
Hope this helps. there should be a .csv attached to this.
olumidekomolafe Thu, 07/02/2009 - 05:59
Thank you Dwane
I have created the file but, yet to upload/test. I will keep you posted how I get on.
