Issue FXO
Answered Question
Jun 18th, 2009
hi,
i have call manager 6.1 with a H323 gateway.
in the gateway i have 3 cards:
- one PRI : the calls work hine ( in and out)
- one card 4-Fxo: with 4 analog line : calls work fine (in and out)
- one card 4-fxo: with 4 gateway GSM: calls from site to outside work fine. but the call from outside dosn't work, the phone rings and when i tray to respond the call hang up :
this the config for the 4 voice port:
voice-port 0/3/0
input gain -3
output attenuation 4
echo-cancel coverage 24
no comfort-noise
cptone FR
timeouts interdigit 6
timeouts call-disconnect 5
timing hookflash-out 500
connection plar opx 100
impedance complex2
caller-id enable
Correct Answer by paolo bevilacqua about 7 years 11 months ago
Can you try "no battery reversal" ?
If still problem, get "debug vpm signal" with "term mon" for a failed call.
Overall Rating: 5 (1 ratings)
dennisbehrens Thu, 06/18/2009 - 09:49
If the call rings properly, but answering causes a disconnect, this usually indicates a codec problem. Can you please post your dial-peers?
bsaid1977 Thu, 06/18/2009 - 10:00
thanks for replay
yes the ring is good, but tha call disconnect when i tray to answeer
the problem is with port 0/3/X
this my all dial peer:
dial-peer voice 100 voip
destination-pattern ...
session target ipv4:172.16.0.254
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 10 pots
destination-pattern 82..........
direct-inward-dial
port 0/0/1
dial-peer voice 11 pots
destination-pattern 83..........
incoming called-number 0522335486
direct-inward-dial
port 0/0/2
dial-peer voice 12 pots
destination-pattern 84..........
incoming called-number 0522972486
direct-inward-dial
port 0/0/3
dial-peer voice 9 pots
destination-pattern 81..........
direct-inward-dial
port 0/0/0
dial-peer voice 1 pots
destination-pattern 9..........
direct-inward-dial
port 0/2/0:15
forward-digits 10
dial-peer voice 125 pots
destination-pattern 7.............
direct-inward-dial
port 0/2/0:15
forward-digits 13
dial-peer voice 126 pots
destination-pattern 800...
direct-inward-dial
port 0/2/0:15
forward-digits 3
dial-peer voice 127 pots
destination-pattern 80..
direct-inward-dial
port 0/2/0:15
forward-digits 2
dial-peer voice 20 pots
destination-pattern 86..........
port 0/3/0
dial-peer voice 21 pots
destination-pattern 87..........
port 0/3/1
dial-peer voice 22 pots
destination-pattern 88..........
port 0/3/2
dial-peer voice 23 pots
destination-pattern 89..........
port 0/3/3
paolo bevilacqua Thu, 06/18/2009 - 10:06
  • Hall of Fame,
    Founding Member
Try:
voice-port x/y
no supervisory disconnect signal
note, if you use trunk-groups, you can reduce the many DPs to a single one.
bsaid1977 Thu, 06/18/2009 - 10:18
yes, i have the same config for both card 4-FXO
the first 4 port is connected to 4 analog lines (to telecom company) and all call are fine from inside to outside and from outside from inside.
but the seconde card 4-FXO are connected to 4 gateway GSM (to mobile phone company), i can make the call from inside to other number in the world, but i can't receive the call( just ring and han up when i tray to respond.
dennisbehrens Thu, 06/18/2009 - 10:19
Have you tried plugging the GSM Gateway lines into the other ports to isolate that it's not the FXO ports?
paolo bevilacqua Thu, 06/18/2009 - 10:21
  • Hall of Fame,
    Founding Member
I've corrected my reply above, try and let us know.
bsaid1977 Thu, 06/18/2009 - 10:30
hi,
this command is to solve another problem, but i have testd this command without result.
yes i have tested the port 0/3/X , they work fine with analog line.
And if the port isn't good i can't make calls from inside to outsider vis this ports.
thanks for advice
bsaid1977 Thu, 06/18/2009 - 10:35
the company phone says that,
how i can use loop Start
paolo bevilacqua Thu, 06/18/2009 - 10:42
  • Hall of Fame,
    Founding Member
Loop start is default.
Ground start is not used outside north america.
Correct Answer
paolo bevilacqua Thu, 06/18/2009 - 10:36
  • Hall of Fame,
    Founding Member
bsaid1977 Thu, 06/18/2009 - 10:41
i have read the document: Document ID: 8120
i used all command in this document, but issue doesn't mutch with this trooblshoot document.
thanks for your best effort
paolo bevilacqua Thu, 06/18/2009 - 10:47
  • Hall of Fame,
    Founding Member
Nobody said that you have a disconnect supervision problem.
Please collect the debug indicated above.
dennisbehrens Fri, 06/19/2009 - 07:48
That looks like battery reversal is occurring and the Cisco gateway is disconnecting the call. Is this with "no battery-reversal" applied to the voice port?
bsaid1977 Fri, 06/19/2009 - 08:17
yes this the problem, thanks for all
now all calls are ok
