Even & Odd Vlan number
Jun 18th, 2009
May be a silly question but i have facing this. Want to know is there any limitation or issue by using VLAN in odd number. B'coz i have Vlan 327(i.e in Odd no.). When i am using this Vlan with same configs ..PPPOEd packets getting dropped and when using VLan no. in even number i.e say 312 i am getting the desired packets.
PLease discuss on this.Is this possible... ?
John Blakley Thu, 06/18/2009 - 09:03
  • Purple, 4500 points or more
The vlan number doesn't matter. It's arbitrary. Your situation doesn't make sense, and shouldn't be affected by the number that you're using.
Can you post the config of these vlans? Is this on a layer 2 or 3 switch?
HTH,
John
