how can i inject the vrf route into globe routing table?
Jun 18th, 2009
and if inject successful,which is the attribute of this vrf route in the globe routing table
thanks!
jcozzupoli Fri, 07/03/2009 - 15:52
I believe by adding the "global" keyword on theh at end of a static route that route will be leaked into the grt.
eg,
ip route vrf TEST_VRF x.x.x.x x.x.x.x y.y.y.y globsl
can you give more details as to why you want to do this?
Are you trying to leak routes from vrfs into the GRT which then is advertised to an ISP MPLS VPN network?
Joe.
thoughtjj Mon, 07/13/2009 - 01:02
HI,
this command is only for the traffic which want to internet from vrf
but how handle with back traffic from internet on the PE,so i ask when this traffic arrive at the PE,it will auto be into vrf ,or must be do some command
thanks!
