MDS license question
Jun 18th, 2009
I am pretty confuse about Cisco MDS trial license. I have found Cisco documents that states that Cisco switches comes with trial licenses and 120 days grace period.
I want to enable IVR (ENTERPRISE_PKG) in a switch that never used that, but the commmand cisco(config)# ivr enable doesn't exist.
Please let me know if there is something to do in order to enable the ivr feature from ENTERPRISE_PKG for a grace period of 120 days.
Thanks in advance.
Juseph
inch Thu, 06/18/2009 - 13:43
  • Bronze, 100 points or more
G'day,
What version of SANos are you using? Earlier versions of SANos did not have the IVR feature.
CHeers
juseph_montesinos Thu, 06/18/2009 - 14:12
thanks for your answer. The SANOS version is 3.2(2c), and does support IVR.
Juseph
emcprateek_2 Sat, 06/27/2009 - 12:09
Use "show license usage" to check if Enterprise package license has expired. Also Cisco MDS 9124 and MDS 9134 do not support IVR.
Hope that helps,
Prateek
Trending Topics: Storage Networking
