Upload greeting wave files into Unity Connection !!!
lindborg Thu, 06/18/2009 - 10:39
the media master control in the admin interface has the option to open a WAV file on the hard drive (i.e. a high quality recording). Under the option menu there's an "open file" - when you save it, it'll get uplaoded.
Note that it'll be translated into a MuLaw mono recording on the way up - so if you record a very HD recording in stereo and such, it wont sound quite the same.
Claudio Quiroz ... Thu, 05/07/2015 - 13:59
Hello Friends,
I have the same problem, I´m working with Unity Connection v 9.1.2, but I can´t see any menu in order to open a file. I only see the "Play/Record" interface . When I press it, Unity shows a message: "InnitApple Failed to get the instance"
Does anyone know about it?
tbytheway Thu, 05/14/2015 - 10:19
That is a Java issue.  In the Java control panel you will need to add the site to the exception site list.  I still get that message even when the aplet loads correctly.
Claudio Quiroz ... Thu, 05/14/2015 - 10:35
Hello tbytheway,
I just added an exception in the list of the Java control panel and the Unity´s app worked properly!
However when I try to upload the wav file to the Unity´s app shows me:
"Could not load audio recording from file. The file is either not an audio file, an unsupported audio format or corrupted "
My wav file is fine because I uploaded it in UCM and it worked properly.
tbytheway Fri, 05/15/2015 - 14:33
It needs to be u-law 8000Hz 64kbps mono.  Is that the format that it's in?  Rarely do recordings come in the format required for Unity.
Carlos Maldonado Fri, 01/08/2016 - 10:35
You can use the website G711.org to convert the audio files to the right format.
BroadWorks Classic (8Khz, Mono, u-law)
