Viewing ACL in a GUI without a firewall
Jun 18th, 2009
In my line of work i have to Q&A firewall configurations ASAs, FWSW, and etc. Alot of times, I find myself loading the configs into the ASA and using ASDM to view the ACLs to see if nothing good is blocked.
My problem is I dont always have an ASA near me all the time. Is there a utility that can show me the ACLS in a GUI (like ASDM) but it doesn't have to connect to a firewall. I can feed the config to it directly.
I was about to write a program to do this, but it might already be available?
Thanks all.
Overall Rating: 5 (1 ratings)
Collin Clark Thu, 06/18/2009 - 10:29
  • Purple, 4500 points or more
I find reading the CLI easier than ASDM. I would suggest learning to read an ACL from the CLI, it will be worth the effort. Post if you need help with reading them.
srue Thu, 06/18/2009 - 10:40
  • Blue, 1500 points or more
ASA has a gui? (:
Collin Clark Thu, 06/18/2009 - 10:46
Ohhh the stories I could tell....
charles.repain Thu, 06/18/2009 - 13:33
Install ASDM Demo.
Go to the programme files/cisco/asdm/versionofasdm/Single_firewall/configs
Backup the actual file "config" and just copy your ASA config in this folder with the name "config".
Now run the asdm demo with the scenarion "single firewall".
You should see almost your configuration. But for the ACL, it's working fine.
