How do I copy and or create PEM file to ACE
Jun 18th, 2009
My apps guys just got back a certificate from Verisign.
I now have to upload this into our ACE
One of the options is to do crypto import terminal <filename> than paste
the cert..
My question is..how do i generate the txt
from the Certifacte so i can cut and paste it into the ACE?
ciscocsoc Fri, 06/19/2009 - 00:17
PEM is a readable text format so if your certificate isn't already in PEM format invoke openssl with the relevant parameters to convert it. Thenn just open the file with your editor of choice.
Cathy
