ASA Webvpn No
Jun 18th, 2009
I have created a new group policy & tunnel group for 2 webvpn svc users. When I connect logging tels me no address is assigned although I have assigned a pool, if I allocate the same pool to the defaultwebvpngroup the user connects ok.
I only want two specifc users to be able to use webvpn
Any ideas why this occurs? and how to remedy?
%ASA-3-722020: TunnelGroup <DefaultWEBVPNGroup> GroupPolicy <Dmz_Users> User <we
buser1> IP <xxx.xxx.xxx.44> No address available for SVC connection
John Blakley Thu, 06/18/2009 - 11:50
  • Purple, 4500 points or more
Can you post your group policy, tunnel group, and user policies? Also need the local ip pool.
HTH,
John
Communications Sun, 06/21/2009 - 07:07
Hi John
Thanks for responding, I have attached the parts of the config you asked for currently I have no pool defined for the defaultwebvpn group as the wrong people can use it and pick up a different pool than they currently get. Ideally I just want 2 specific users to be able to use the web access
