CUCM 7.0 Billing Server configuration question
Jun 18th, 2009
When you add a new billing server to CDR Management, does it send over all entries in the CDR database or only records generated since the billing server was defined in CUCM?
Jaime Valencia Thu, 06/18/2009 - 10:48
It starts sending from the moment you configured it onwards
java
if this helps, please rate
jhindmarsh Thu, 06/18/2009 - 11:51
Is there any way to get the system to push previous data out to the billing server?
