"Times to Re-prompt Caller" V.S. "Delay Between Re-prompts" in UC
Answered Question
Hi all what is the difference between
in UC when configuring a greeting?
Best regards,
Correct Answer by Jaime Valencia about 7 years 11 months ago
I believe it's pretty obvious.
How many times you will hear the prompt and how much time between playing prompt N time and playing it N+1.
If you set 4 times and 10 seconds... you'll hear it 4 times and there will be 10 seconds between each time.
You can always use the help -> for this page option if you need to understand what each parameter is for.
It also solves your other post:
Playing the same greeting several time in UC !!!! ( if no input)
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/18/2009 - 12:23
  • Cisco Employee,
  • Hall of Fame,
    2011
java
