Integration Callmanager and Unity Server
Jun 18th, 2009
Hi team,
I am trying integrate a callmanager server to unity server and I am not getting. When I go in the menu "Telephony Integrations->Phone System" and try to add on the screen "Set up Port" he answered "Server <Address IP> Did not respond". The Port 9999 is the port would be configured in the DN callmanager correct?, I created the "voice mail port and used the DN and still does not work. Someone could help me see where I'm wrong.
Jaime Valencia Thu, 06/18/2009 - 13:53
If i have an IP config box and below a port config box, the only thing i could think of, would be TCP or UDP ports. It would never cross my mind they're talking about a DN.
To Add a UTIM Cluster to a Cisco Unified CM Integration
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/cu4xintskinnycucm6x.html#wp1842814
If you're noob with the integrations better start off by reading the integration guides and then doing the actual process.
Change 9999 to SCCP port.
java
if this helps, please rate
