Need to Broadcast One SSID and Not Another
Jun 18th, 2009
Hello All,
I'am trying to configure an 1130 AP to send out 2 SSID's, each SSID is tied to a different vlan. I set guest mode on the one I want to broadcast and it works fine, however the other SSID I can't see when I manually configure it on my laptop, it only used MAC-authentication. When I enable MBSSID guest mode on both SSID's, I can see both and connect to both. Do I have to broadcast both? Thanks
dancampb Fri, 06/19/2009 - 05:32
  • Cisco Employee,
You shouldn't have to broadcast the SSID to be able to connect to it but some supplicants do prefer it such as Windows Zero Config.
