ONS 15454 error message
Jun 18th, 2009
Hi Expert,
I have a problem with ONS 15454 error message. My CTM server detected MINOR error message "Peer to Peer Slot Communication Failure". Affected object is SLOT-1 which is OPT_BST. The alarm ID is 200551. What caused this error appear and any workaround to solve this problem?. Your kind attention is much appreciated.
Tom Randstrom Fri, 06/19/2009 - 06:34
  • Gold, 750 points or more
Although the following alarm is not identical to the one you identified, this seems to indicate the a peer "communication failure" is hardware related.
2.5.237 PEER-NORESPONSE
Default Severity: Major (MJ), Non-Service-Affecting (NSA)
Logical Object: EQPT
The switch agent raises a Peer Card Not Responding alarm if either traffic card in a protection group does not receive a response to the peer status request message. PEER-NORESPONSE is a software failure and occurs at the task level, as opposed to a communication failure, which is a hardware failure between peer cards.
Hope this helps....
