Capturing VPN traffic on Cisco 857W
Giuseppe Larosa Thu, 06/18/2009 - 23:50
Hello Kieren,
if your "WAN" interface is a LAN interface and you have a Cisco switch you can configure the switch to mirror traffic of the port where you connect the C857 WAN port to another port where you connect a laptop with a SW protocol analyzer.
IF you refer to embedded packet capture it shouldn't be supported on the 857 according to
that lists C7200 and ISR as supported platforms.
Hope to help
