Switchport Config - Trunk or Access?
Answered Question
Jun 18th, 2009
Just wondering if Cisco has any recommendations around whether to configure the switchport as a trunk or as an access port for Lightweight Access Points?
We've been running some LAPs connected to trunk ports and some connected to access ports and we can't really see any difference.
We're guessing that the trunk port will allow 802.1p values to be carried in the frame, where an access port won't.
Can anyone provide any clarification or recommendations around this for us?
Cheers,
Dave.
Correct Answer by George Stefanick about 7 years 7 months ago
When an AP joins a controller it creates an LWAPP tunnel adjacency (if your are on 5.2 code, it's a CAPWAP tunnel). Like most tunnels, all your traffic is aggregated within the tunnel itself.
So your vlans, qos, ssids, and traffic transverse the LWAPP tunnel, so there is no need to config the access switch with a trunk.
Your aps dont attach to the manager interface, but rather to the AP manager. I forget what code version the ap manager goes away, but you get the point.
Overall Rating: 5 (2 ratings)
Leo Laohoo Thu, 06/18/2009 - 20:44
Hi Dave,
Does your switchport carry two or more VLANs (like voice and data)? If yes, then it's recommended that you configure the switchports as trunks. Otherwise, if you only have one VLAN, then access would do just fine.
Hope this helps.
david.kelsen Thu, 06/18/2009 - 21:26
Thanks Leo,
Yes the switchports do carry two vlans, as mentioned, voice & data... in fact three vlans if you include the management vlan. So it would make sense to configure them as trunks... but...
The LAPs connected to access ports still pass all traffic, whether its voice, data or management.
That's whats led me to post the question.
Its got me a bit confused.
Leo Laohoo Thu, 06/18/2009 - 21:40
Hi Dave,
You can always "allow" the specific VLANs you require:
switchport trunk allowed vlan Management,Voice,Data
Just substitute the "Management,Voice,Data".
Does this help?
George Stefanick Fri, 06/19/2009 - 01:04
Leo,
Dave mentioned these were for lwapp access points. These should always be access ports ...
see attached
While the Cisco WLCs always connect to 802.1Q trunks, Cisco lightweight APs do not understand VLAN tagging and should only be connected to the access ports of the neighbor switch.
http://74.125.47.132/search?q=cache:1pLYVU-lw70J:www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml+lwapp+access+trunk&cd=4&hl=en&ct=clnk&gl=us
If these were autonomous, then yes you would need a truck. But not with LWAPP... but hey you boyz from down under have a whole different way of doing things lol!
david.kelsen Fri, 06/19/2009 - 22:34
Hi gstefanick,
Thanks for your reply.
I've checked out the link and it seems to answer my question when it says that, 'Cisco lightweight APs do not understand VLAN tagging and should only be connected to the access ports'...
So I'll correct any LAP switchports that are currently configured as trunks.
How does it work though? Ie., having multiple vlans, but the LAP is attached to an access port in the management vlan.. how does the voice & data traffic get switched?
Correct Answer
George Stefanick Sat, 06/20/2009 - 04:02
david.kelsen Sat, 06/20/2009 - 16:54
Cool, that explains things.
Yeah we're running 5.2 code, so it must be a CAPWAP tunnel.
Thanks for all your help.
Leo Laohoo Sun, 06/21/2009 - 14:46
Hi George,
I had LAPs connected to access port and AP's connected to Trunks. Don't see any difference. He he he ...
Leo Laohoo Sun, 06/21/2009 - 18:21
The 5508 does not use AP-Manager. Optionally, you can have Dynamic AP-Manager.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
