checking unified Voicemail from landline
Jun 18th, 2009
I have set up a voicemail box and I am able to check voicemail internally in the company.
I am also able to dial into unity from externally to check the voicemail message using mobile phone.
However, it seems that when trying to dial into unity using landlines... then after i entered my extension the voicemail box said "invalid entry".. I have tried to use different phone outside of the company and it still the same.
however, if I dial into the unity checking the voicemail by dialing outside line then followed by the full number, it works..
it just didnt work when using any other landlines phone outside of the office( but work with mobile)
any idea?
Rachel
culittle Fri, 06/19/2009 - 09:32
Problem is not going to be in Unity. The DTMF digits are recognized by some device before it gets to Unity. Probably a gateway. I would identify the components in the call path of a working call v a non working call. Also Phone location.
