nss6000 will not join sbs 2008 domain
Jun 18th, 2009
I updated the firmware to the latest rev on the device & are their any docs. on the procedure to do this?
Want to make sure it is not a syntax issue
clindoan Fri, 06/19/2009 - 09:02
It would be exactly like the SBS2003 procedure. You would need to setup the SBS 2008 domain first, the procedure can be easily found on Miscrosoft web site. The release notes said: " No support for SBS 2008" but I found it is working fine with latest firmware V1.14. Here is the link to build the 2008 domain server:
http://www.windowsreference.com/windows-server-2008/step-by-step-guide-for-windows-server-2008-domain-controller-and-dns-server-setup/
Hope that 's helped.
kevanh Fri, 06/19/2009 - 12:06
Thanks for the reply.
This NAS device connects successfully to a 2003 domain controller. It is not a setup issue.
There is some configuration issue with SBS 2008 (IPSec maybe) on by default which needs to be turned off to be compliant to SBS 2003
I will keep looking
